Re: Reinstalling Dist on Farmall 300?
Posted by MagMan on December 11, 2004 at 14:39:39 from (205.188.117.13):
In Reply to: Reinstalling Dist on Farmall 300? posted by Kelly C on December 11, 2004 at 14:33:01:
Hi Kelly,
The way I understand it is TDC compression stroke ,Check the pointer on the front to see if its in line with the pully then put the distributor so its just starting to go on #1 plug on the dist cap then install distributor gear so it lines up with mount then mesh it with the distributor and put her on then time it.
JON
Post a Followup
Subject:
