Re: Ok, nothing is working now on my H. Please he
Posted by Gene on December 11, 2004 at 15:02:10 from (208.144.172.150):
In Reply to: Ok, nothing is working now on my H. Please help. posted by tanner clark on December 11, 2004 at 14:37:00:
Take two deep breaths and have a cold beverage.
1) Distributor cap shouldn't be wiggling - It's probably not locked down properly - any way this problem must be solved.
2) My guess. You have no voltage going to the coil then distributor or you have a short in the distributor. Remove the wire going from the coil to the distributor - ignition on, check for voltage. No voltage trace back until you find the problem.
Voltage at the coil. Set the meter on OHMs and check the terminal at the distributor - you are looking for a short.
Good luck
Post a Followup
Subject:
