Re: 1976 Cub Cadet Electric PTO
Posted by Novel Idea Guy on December 12, 2004 at 08:06:19 from (24.24.37.180):
In Reply to: Re: 1976 Cub Cadet Electric PTO posted by John J. Wach on December 12, 2004 at 05:54:58:
Of course nothing is happening. The engine isn't running. Were you expecting the mower to start turning? It's just an electric PTO CLUTCH, not an electric motor that drives the mower.
All you've proven is that the wiring is good. If you want to know whether or not the clutch is grabbing, you need to start the engine, or turn the mower over by hand. If you can't turn the mower over by hand when the clutch is engaged, then it's working.
Post a Followup
Subject:
