Farmall Tractors Discussion Board
Re: Re: Hy Trans Fluid
Posted by bill on November 23, 1999 at 03:12:46 from (152.163.207.211):
In Reply to: Re: Hy Trans Fluid posted by Corky on November 23, 1999 at 00:45:23:
check the engine oil level it might be leaking in to the crankcase from the hyd. pump seal.check the screen in the reservere make shure it is clean.
Post A Followup
: Re: Re: Re: Hy Trans Fluid
