Re: drain holes?
Posted by DWV on December 13, 2004 at 17:50:01 from (64.12.117.13):
In Reply to: Re: drain holes? posted by iester on December 13, 2004 at 16:28:54:
If you have T/A and live PTO it should be HY tran
or equivalent oil that is leaking out.Every thing from engine back uses it.I know its a job on utility but theres a plate covering top of clutch housing with a smaller plate on it.Remove plates and you can usually tell which seal is leaking.
If seal toward front of tractor is leaking it can be got to by splitting at rear of engine.If ones to rear are leaking T/A housing and T/A need removed.I would do them all if tractor is apart.
Think Kelly C has pictures on row crop teardown somewhere on site.
Post a Followup
Subject:
