Re: fouling plug
Posted by mowr on December 13, 2004 at 19:25:44 from (67.96.2.205):
In Reply to: fouling plug posted by PHIL IN NWMO on December 13, 2004 at 17:44:19:
If you are using D-15Y plugs, a D-18Y on that one cylinder should be enough hotter to make a difference. If you"re already using D-18Y"s, then go to D-21 on that one. This often solves the problem and for much less than an overhaul.
Post a Followup
Subject:
