Re: farmall 300 wide front end
Posted by Red rider on December 13, 2004 at 20:04:18 from (66.235.45.149):
In Reply to: farmall 300 wide front end posted by comradwade on December 13, 2004 at 08:41:17:
comradwade, actually the wide fronts all the way up to a 1206 will fit. The only difference will be the stay rod bracket for the M through the 1206 will be to wide. You will either have to make one or find the factory one which will cost you an arm & leg. I built a star rod bracket for my 300. Pretty simple. If you want I can post a picture of the bracket I built.
Post a Followup
Subject:
