Re: fouling plug
Posted by El Toro on December 14, 2004 at 04:16:05 from (66.119.33.154):
In Reply to: fouling plug posted by PHIL IN NWMO on December 13, 2004 at 17:44:19:
Hi Phil, Is that plug fouled from oil? You may have oil getting past the rings if it is. If your plug is too cold, the hotter plug may fix the problem it unless it's covered in oil. Hal
Post a Followup
Subject:
