Seat Frame/TA Lever
Posted by PAULIH300 on December 15, 2004 at 16:41:51 from (152.163.101.13):
What color should the seat frame be on a 300U?
Also,what color is the Torque Amplifier lever?
Has anybody come up with Aftermarket (like MOOG)tie rod end numbers for the wide front end? They look like simple large truck (like 50/60 series) ends.
Post a Followup
Subject:
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
