W-30: Need info here's some
Posted by dlp on December 15, 2004 at 17:41:22 from (12.73.205.189):
I"m in the process of doing a rebuild on my W-30. I"ve got 3 engines, one out of a F-30 & 2 out of W-30"s. Now I"ve got 3 different style of governors. How many different ones were used? To my understanding, A W-30 shares only the crank & rods with a 10-20. You can interchange the pistons, but you have to use the right rings for that piston, they are different. The main bearings, 314 & 316, can be had at a bearing warehouse. It pays to shop around on pricing also. There are 2 styles of each bearing. One is a standard & the other is a "max" bearing, which was the original style. The max bearing has extra rollers to give it more strengh. I"m going to use standard bearings, mainly because not only are they considerably cheaper, this machine"s working days are over, just shows & maybe a pull or two. I had my valve guides drilled & inserted. The intake valves are out of a Cat {we think} & were cut & grooved to fit. If the cylinders are too worn, I believe that the wet sleeves can be bored & a liner pressed into them. Then bore it out to give the proper clearance to the piston. With valves running around $30 a piece & cylinders $200-$250 a hole, A guy looks for other means! I noticed a posting concerning rebuilding a 30 engine the other day, this is just my 2 cents worth. Of by the way, I"m going two stand my engine up on it"s nose & use my cherry picker to lower the crank down into postion. Hope some of this helps!
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
