Re: Farmall A cooling system
Posted by Jim Becker on December 16, 2004 at 09:59:07 from (4.29.46.107):
In Reply to: Re: Farmall A cooling system posted by Haas on December 16, 2004 at 06:00:59:
The temperature gage was available as a separate option on the gasoline tractors. It was part of the shutter attachment and may have also been available by itself.
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
