Re: Fluid level for Farmall A
Posted by Andy Martin on December 16, 2004 at 12:59:01 from (64.219.39.195):
In Reply to: Fluid level for Farmall A posted by jons on December 16, 2004 at 12:18:52:
The left side of the tractor, beside the brake rod is a small pipe plug. This is the fill level, and it is low on the housing.
Transmission and rear end are filled at the same point, though there are two drain points.
If you have a belt pulley on the back, you should also fill it. Fill it first as I believe the excess drains into the gear box.
80w90 or 140w gear grease will work fine. Some recommend Hy-Tran but it leaks easier and you might get more gear noise. Gear grease was originally resommended and they recommended Hy-Tran in later years. The gear grease available today is better than what was available when they sepcified it originally.
Post a Followup
Subject:
Today's Featured Article - On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play ... [Read Article]
