Cleanliness!
Posted by Steve from MO - dangit! on December 16, 2004 at 13:51:15 from (168.166.54.11):
In Reply to: Soaking a carb? posted by Kelly C on December 16, 2004 at 08:13:36:
I usually have good luck but I am not into the long soaking habit. I use either carb or brake cleaner depending on which is handy, but I make sure to take all the lines off and needle valves out before I use the cleaner to blow out the passages. A long-dead gunked up carb might require a brass wire up the narrower passages to get the cleanout started.
Post a Followup
Subject:
