Re: clutch noise on A
Posted by Brian Schmidt on December 16, 2004 at 14:11:16 from (12.218.36.164):
In Reply to: clutch noise on A posted by Jons on December 16, 2004 at 08:30:57:
It is definitely not the pilot bearing. That would make noise or shutter when the clutch is depressed or when you are releasing it. It could be either gear noise on the tranny or throwout bearing. Does the noise stop when you just apply pressure to the pedal without disengaging the clutch? The tranny will still be spinning. If there is no noise then, it is the throwout bearing. They tend to get quite under a load and growl when only lightly loaded.
Post a Followup
Subject:
