Re: pull dist and pump?
Posted by Theman on December 17, 2004 at 06:27:54 from (65.248.77.5):
In Reply to: pull dist and pump? posted by iester on December 16, 2004 at 18:16:23:
Only if you absolutely have to. If you decide there's no other way, I recommend you set the #1 cylinder to compression top-dead-center (TDC) and mark the position of the distributor rotor before removing anything. That way it will be easier to set the engine timing upon reassembly.
Post a Followup
Subject:
