Re: Tire spins on right side of Farmall 100 when w
Posted by Bill in Orono, MN on December 17, 2004 at 06:45:26 from (67.4.199.210):
In Reply to: Tire spins on right side of Farmall 100 when worki posted by Ramon from NC on December 17, 2004 at 06:33:48:
You are correct that an uneven amount of weight is on one side.
Try moving some weights over to the other side.
Other things to try in addition to the above.
Air pressure, lower will give you more traction.
Are the tires identical? If not that may aggrevate things a bit.
Try using the brake (L or R) to stop the spinning tire. This will
transfer power to the other wheel.
Post a Followup
Subject:
