Re: Rollover Plow and Dead Furrow question?
Posted by ShepherdBill on December 17, 2004 at 06:50:05 from (152.163.101.13):
In Reply to: Rollover Plow and Dead Furrow question? posted by Ramon from NC on December 17, 2004 at 06:23:59:
I thought the two-way plow was the normal plow. One-ways are not common and seldom used in this neck of the woods.
Ramon, you're right the rollover or any two-way plow turns the first furrow on unplowed ground and leaves. With a one-way you end up with a double open furrow in the middle of the field (or land) or a double mound, depending which way you start. Of course, with a two-way you have to plow in the turn around areas on each end of the field.
Another thing, if you irrigate with furrow, you can plow with the furrow rather than plow across them, much smoother. IMO, two ways especially those mounted on the tractor are much more efficient in small fields. If you have large field and don't have to irrigate, a one-way might work as well. However, I'd probably want to use a two-way because one-ways never worked as well where I live.
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
