300U/C169 Alternator Conversion
Posted by PAULIH300 on December 17, 2004 at 10:35:13 from (64.12.117.13):
I have fabricated a mounting bracket for a 10SI GM alternator (1 wire),I now have a problem with fabricating an adjusting lever that will meet up with the factory strap.I also fear the new alternator is going to stick out too far to the side and hit the hood (when I put that back on) without cutting a chunk out of it.Anybody else mount a GM alternator on a 300U? And if so,how did it fit? (I know the belt is going to have to be quite a bit shorter).
Post a Followup
Subject:
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
