Re: Wireing diagram for converting 300 to delco al
Posted by F-Dean on December 18, 2004 at 06:23:35 from (12.74.47.10):
In Reply to: Wireing diagram for converting 300 to delco alt? posted by Kelly C on December 17, 2004 at 22:31:38:
Double check what gound the alternator needs. When you put a Hitachi alternator on a "M" you have to switch to a negative ground.
Post a Followup
Subject:
