Re: Wireing diagram for converting 300 to delco al
Posted by Bob M - nope! on December 18, 2004 at 06:41:09 from (69.201.120.79):
In Reply to: Re: Wireing diagram for converting 300 to delco al posted by Kelly C on December 17, 2004 at 23:20:43:
Kelly - If you install a 12 volt (internally ballasted) coil the external resistor is not needed! ...Bob M
Post a Followup
Subject:
