Re: rear frame
Posted by RustyFarmall on December 19, 2004 at 04:36:10 from (216.248.75.131):
In Reply to: rear frame posted by mikefmny on December 19, 2004 at 04:26:30:
There a quite a few Farmall M tractors that suffered the same type of bearing failure, resulting in a hole in the bottom of the case. The bearing was replaced, the hole patched up, and most of these Ms are still working. Listen to your welder friend.
Post a Followup
Subject:
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
