Re: 5088 Questions
Posted by K.B.-826 on December 19, 2004 at 18:44:16 from (209.163.30.18):
In Reply to: Re: 5088 Questions posted by Leo Crall on December 19, 2004 at 17:20:59:
The transmission is very similar to the Case-IH Magnums, but it is not a full powershift. Basically, you have two levers, one to shift the four ranges- high, medium, low, and reverse, and the other lever shifts the six speeds. 1 and 2 are located right across from each other, and you can powershift between them. If you want to shift to 3 or 4, you need to clutch, but the transmission is syncronized like a Deere, so you can shift on the move. Once in 3 and 4 you can powershift between them. Once again, you need to clutch to get to 5 and 6, but you can powershift between them. You also need to clutch to shift between ranges. When the Magnums came along, Case-IH just replaced the syncros with hydraulic clutch packs, and this transmission became a full powershift.
Post a Followup
Subject:
