I guess it just depends on the person buying it. As far as I'm concerned it would significantly lower the value for me. Those tractors were designed to be used with a TA and are really quite efficient if maintained properly. While the TA was known to be a little tempermental most of the problems arose from operator abuse and improper adjustment. Adjustment of clutch, TA,etc. is crucial with these units. You really have to watch it when someone is claiming to have a tractor with the TA delete option. IH did offer this option on most tractors. Most of the time though someone has either removed the TA lever or gutted the TA and put a shaft in it to eliminate it. There is a big difference. The genuine TA delete option from IH may have some value for collectors. The ones that have been scrapped or cobbled are worth a lot less in my opinion.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
