Re: Adjust a radiator
Posted by Dave (IL) on December 21, 2004 at 04:37:32 from (67.162.24.37):
In Reply to: Adjust a radiator posted by tom west on December 21, 2004 at 00:54:49:
"small valve that can be pushed down"? Hot water radiator with boiler (furnace) ? Should be a water loop from boiler to bottom of radiator on one side, out the other and back to boiler. Usually a valve on one end or the other, sometimes valve is in basement. Sometimes handle on valve can come loose. You might be able to take handle off and turn with vice grips. Caution, if valve breakse or packing breaks you could get sprayed with hot water. Plus you'd really need the plumber then. Check out the water "circuit" first. Look for valves shut off. Check pipes for heat from furnace to radiator. Hot water can be on pumped loops or sometimes gravity only feed. Could be one radiator on a pump that's not working. Also usually an air bleed valve on TOP of radiator. a little valve that uses something like a skate key to open and bleed air from the radiator. If it's full of air it won't heat. Sometimes there's a parallel loop of pipe that bypasses radiator so valve can be off and water will still circulate, especially if there are other radiators in series. Careful in this weather. If they are off in this weather they CAN freeze and break pipes or even the radiator. Steam is similar, but probably a little more dangerous if you get a sudden leak. Steam goes up and condensate comes down. Maybe try the tool forum for a professional plumber.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
