Re: 230 vibrating driveshaft
Posted by El Toro on December 21, 2004 at 16:48:17 from (216.148.246.154):
In Reply to: 230 vibrating driveshaft posted by Randy Laskody on December 21, 2004 at 15:03:38:
Hi Randy, It sounds like your spline may be worn where it connects to the engine. The clutch
disc may also be worn and the disc may be broken too.
At sometime you will probably need to tear into it. Parts are probably available
and you'll need to split the tractor so you can determine what parts are required. Hal
Post a Followup
Subject:
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
