A Super A Question
Posted by Charles Houston on December 21, 2004 at 18:26:00 from (64.7.233.63):
The hydraulic rod that connects the touch control hydraulic arm to the rear lift assembly has a hugh rainbow curve in it instead of being straight. The lift arms on the rear of the tractor are grossly misaligned on the cross shaft. I think the left rear lift arm weld was broken loose on the shaft and welded back off location. How can I check this out and correct it the way it is supposed to be? All replys appreicated. Thank you.
Post a Followup
Subject:
