Re: My M has a miss
Posted by El Toro on December 21, 2004 at 19:22:07 from (170.224.224.122):
In Reply to: Re: My M has a miss posted by MagMan on December 21, 2004 at 14:12:25:
Hi Jon, I still have one of those valve spring compressor's to use when you apply air to a cylinder.
Once you got No1 cylinder at TDC on the compression stroke, I'd would go through the firing order with ignition key on and the next
sparkplug wire connected to a plug until that plug
fired. It was very easy with a helper rotating the engine with a ratchet. I was changing the valve seals. Have a Merry Christmas, Hal
Post a Followup
Subject:
