Re: 230 vibrating driveshaft
Posted by EricB on December 22, 2004 at 06:01:18 from (216.209.84.11):
In Reply to: 230 vibrating driveshaft posted by Randy Laskody on December 21, 2004 at 15:03:38:
Randy:
When you say driveshaft, do you mean crankshaft or transmission spline?)
If you can move the end of the crankshaft with a bar you are looking at more than a pilot bushing. I'd be prepared for a big end bearing. Does it leak oil into the clutch housing?
Check you transmission and engine mounting bolts. Make sure the engine and transmission are bolted tight. This sounds stupid but it can happen.
If you hace crank bearing problems there is a manufacturers warning NOT to turn the crank on these models. It is a replacement item. Turning the crank goes below reissued specifications.
As far as those rims go; I removed my tires and resurfaced the inside with fibreglass resin. You can rebuild bad areas and it doesn't corrode.
Post a Followup
Subject:
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
