Re: 6 volts to 12
Posted by PAULIH300 on December 23, 2004 at 18:19:08 from (64.12.117.13):
In Reply to: Re: 6 volts to 12 posted by Doug in OR on December 23, 2004 at 17:43:21:
Use the smallest dia pulley you can get.That will up the rpm as much as possible.Otherwise,a Delco alt can be wired with 3 leads (batt/key/indicator light) and then the low rpm deal wont be an issue.
Post a Followup
Subject:
