Re: 6 volts to 12
Posted by Mo Hay Baler on December 23, 2004 at 22:43:33 from (69.27.212.175):
In Reply to: Re: 6 volts to 12 posted by john -dubuque ia. on December 23, 2004 at 12:17:57:
The one wire alternator is fine.The wire should be hooked to an ignition source terminal thats only hot with the switch on,this will excite the alternator and it will cut out as long as it has an internal regulator.The reason it drains the battery is because it is hooked to a source thats continually hot,and that drains the battery.
Post a Followup
Subject:
