Re: Farmall H Lift All Pumps
Posted by Ken K on December 24, 2004 at 01:32:01 from (63.26.16.205):
In Reply to: Farmall H Lift All Pumps posted by Ian T on December 23, 2004 at 23:22:19:
The Lift-All pump is set up for one way hydraulic (single acting) cylinders only. One side has only one pipe and the other side has two. Right side and left front side outlets are direct pressure while the left rear outlet is kind of indirect pressure which I will explain. This system was designed for lifting front and rear cultivators. A one way cylinder on each side of the tractor lifted the front cultivators and the third (rear outlet) lifted the rear cultivators with a 3rd cylinder. The rear has a built in delay in the pump so the front would lift first, then when the pressure built up in the front cylinders, the rear cylinder would lift the rear cultivators. You can't use this system as it is for a cylinder or motor where you need a return pressure line, like a duel acting (two way) clyinder or motor. You can add a two way valve for this purpose by using the outlet on the right side and putting a T in the oil fill pipe for the oil return. There is a small hole for a breather in the oil fill cap that has to be pluged when using a two way valve or you will get oil comming out of the breather hole. Then you lock the Lift-All pump lever on so you have constant pressure to the new two way valve. IH made a two way valve conversion package for the early H & M's. On later H & M's this package was an option from the factory. (Some times this valve is referred to as the Christmas Tree valve!) This option is showen in the late H & M and Super H & M Owners Manual. One bad thing with these pumps is they had only 800 pounds of hydraulic pressure which may or may not be enough pressure to run your grain auger motor. I think it would be worth a try. Ken.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
