Re: Battery what should I do??
Posted by JB2 on December 24, 2004 at 12:16:37 from (24.157.143.220):
In Reply to: Battery what should I do?? posted by terryj on December 23, 2004 at 23:01:37:
Hi, generators produce DC current and the voltage you read is the charge stored in your battery.
To charge a lead acid battery requires DC current flow through the battery to restore the chemical balance.
The voltage is a measure of the percent charge of the cells. The voltage regulator is adjusted to stop the generator from charging when the battery reaches a certain voltage level.
I hope this made sense.
JB2
Post a Followup
Subject:
