Re: 1066 Hydro hydraulic cooler leaking
Posted by Daniel Ovaert on December 24, 2004 at 12:41:52 from (4.162.114.144):
In Reply to: 1066 Hydro hydraulic cooler leaking posted by Danny Ovaert on November 07, 2004 at 09:22:16:
The hydraulic cooler on 1066 hydro's is a very hard part to locate. It's actually a heavy guage aluminum radiator that most radiator shops won't touch.
I did find someone in Dallas that would build me one for $700.00. I would have gone on and done that except it was going to take a month to build
and I needed the tractor.
So I decided to see if I could find one. I was looking at the radiator in my shop and decided to try a temporary repair. So I presurized the radiator and precisly located the leak. It was a small pinhole leak on one of the cores. I then cut the fins out around the leak and cleaned the area with muratic acid. Then I put foil tape on one side and filled the cutout area with JB weld. It worked! I have been using the tractor for months with out a leak.
Regards,
Danny
Post a Followup
Subject:
