Re: 52' Farmall SM rear end froze
Posted by steveormary on December 24, 2004 at 18:44:27 from (222.124.44.121):
In Reply to: Re: 52' Farmall SM rear end froze posted by Shaggy on December 24, 2004 at 14:37:19:
Hy Tran will work just fine and it is or was cheeper then the 90 wt. We used this in all our Farmalls.
steveormary
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
