Re: Super A: Carb
Posted by El Toro on December 27, 2004 at 08:07:06 from (66.119.33.186):
In Reply to: Super A: Carb posted by PaulG on December 26, 2004 at 17:55:14:
Hi Paul, Sounds like that new float seat and needle are leaking fuel or your float level may be set too high. Has it ever run ok since you redid the carburetor and did it do this prior to installing the new carb parts? Be sure the float isn't rubbing against the sides of the carburetor.
This can keep the float from shutting off the fuel. Does the fuel drip when the tractor is just sitting with the engine off and the fuel
shutoff is in the open position? Hal
Post a Followup
Subject:
