Re: 19?? Farmall H
Posted by MagMan on December 27, 2004 at 12:08:28 from (64.12.117.13):
In Reply to: 19?? Farmall H posted by WOD on December 27, 2004 at 10:19:59:
The motor block if origanel should have the serial# stamped in it on the RH side looking from sitting position. Its above the dist or mag there is a flatened metal smooth spot with the serial # stamped in it the only way to get rid of this one would be a grinder. JON
Post a Followup
Subject:
