Re: Bosch starter problems... suggestions?
Posted by Randy in NE on December 28, 2004 at 04:03:57 from (216.58.237.20):
In Reply to: Bosch starter problems... suggestions? posted by fixitforfree on December 27, 2004 at 20:10:08:
I'm not saying it isn't the starter. But there are a couple of things that I would try first. The cheapest being to ensure that the battery connections are good. This includes both ends of each of the battery cables. The battery needs a really good ground connection to complete the circuit. Next I would try new heavy duty battery cables. Hugh MacKay, myself, and others have stated the importance of good cables. Try 1 gauge or even better would be 0 gauge cables. If you had the started tested at your reliable shop they should have been able to tell you if the starter was good or not. Just because a starter looks like new on the inside doesn't mean that it is. They can test the windings and a good shop will be able to tell you if it "is" good.
Post a Followup
Subject:
