Re: 6 Volt Battery Pack
Posted by El Toro on December 28, 2004 at 12:35:18 from (216.148.244.90):
In Reply to: 6 Volt Battery Pack posted by RETCOL on December 26, 2004 at 11:27:21:
You should get a battery charger that has booster
starting amperage. Northern tool has a 200 amp
charger for $119.00. It's for 6 & 12 volt batteries too. The item number is 167756-1502.
Their toll free number is 1-800-533-5545.
We had a truck with a big DC generator that was driven from the transfer case so we could slave
(jump) start tanks or trucks. Most military vehicles are 24 volts, but we could get 12 volts too. That booster makes a big difference in cranking speed. Hal
Post a Followup
Subject:
