Re: Cub flooded
Posted by El Toro on December 29, 2004 at 03:20:46 from (66.119.34.58):
In Reply to: Cub flooded posted by Kevin (FL) on December 28, 2004 at 21:55:05:
Hi Kevin, It's possible that you may have bent a rod, but I doubt it. I would pull all the plugs and crank the engine over with the ignition switch
off. I would blow air over the plugs with with an air hose to dry them off. I would squirt engine oil into the cylinders and crank the engine
over to coat the cylinder walls, then I would squirt a little more oil into the cylinders and then reinstall the plugs. I would then see if
the engine will start.
If that carburetor is still dripping fuel, I would put a kit in that carb and you may need to disassemble it and soak it in carb cleaner. Have a Happy New Year, Hal
Post a Followup
Subject:
