Re: farmall f-12
Posted by Fawteen on December 30, 2004 at 15:27:19 from (65.99.191.12):
In Reply to: farmall f-12 posted by trickie-mi on December 30, 2004 at 15:16:27:
Electric start was not a common option for the F12/F14. They exist, but they're somewhat rarer than an honest politician, and dang near as expensive.
As to getting it started (assuming it's not stuck) thoroughly clean the entire fuel system, change all the fluids, put a fresh set of plugs in it, clean or replace the points in the mag, spin her over with the plugs out to see if the mag is hot, maybe run a compression check and then commence cranking.
You might have better luck pulling it with another tractor until you find all the little bugs.
Post a Followup
Subject:
