Re: farmall f-12
Posted by NEsota on December 30, 2004 at 17:37:26 from (4.158.72.223):
In Reply to: Re: farmall f-12 posted by jason(ma) on December 30, 2004 at 16:26:26:
If your F12 has the original mag, it should connect to a 3/8 inch lever 4 inches long below the right side of the steering wheel. If turned to the left, that is OFF. If vertical, that is the start position and the spark is retarded, so that you don't get kicked when cranking, due to back-fire. Turned to the right is RUN. I am familiar with this tractor and you may call me to talk. 612.929-4011
Post a Followup
Subject:
