Re: Motor oil
Posted by PAULIH300 on December 31, 2004 at 10:12:02 from (152.163.101.13):
In Reply to: Re: Motor oil posted by Randy from Pa on December 31, 2004 at 06:31:28:
Old ND oil (SA Rating) has no friction reducing additives like most all modern oils have gained thru the years.A ND will heat up more,break down due to heat faster,and will not conserve fuel.It also wont float internal crap to the oil filter,the heaviest junk will stay put or drop to the bottom (the pick up screen).Basically,with only a few exceptions,there is little need anymore for ND oil.Do your engine a favor and only feed it the best modern oils you can find. As far as going to synthetics (if you're tempted),I wouldnt.If the engine was rebuilt or re-sealed you might not have a problem,but synthetics dont get along too well with 50 year old seals....
Post a Followup
Subject:
