Re: 460 farmall will not start ....NEED LOTS OF HELP!!!
Posted by El Toro on April 04, 2009 at 08:59:14 from (205.188.116.73):
In Reply to: 460 farmall will not start ....NEED LOTS OF HELP!!! posted by ky's861 on April 03, 2009 at 14:42:11:
You need to pull off a plug wire and have someone make an attempt to start the engine. Hold the plug wire 1/4" away from a good ground or the plug to see if you're getting fire to the plugs.
If you're not getting a hot spark to the plugs run some 320 wet or dry through the new points. Make sure your plug wires are in the correct firing order on the cap. Should be 1-5-3-6-2-4 Hal
