Farmall Tractors Discussion Board |
Re: 240 Just won't run
Posted by Paul Fox on November 25, 1999 at 08:20:34 from (204.176.212.3):
In Reply to: 240 Just won't run posted by Brian on November 25, 1999 at 07:33:33:
A bit more information would help. I'm assuming it's electric start. If so, is the battery up? When you hit the start button, does the starter turn? If not, check the battery cables, make sure they are clean and tight. If it is, is it engaging the ring gear on the flywheel and turning the engine? If the solenoid isn't working, with starter will spin without turning the engine over. You could also have a couple of broken teeth on the ring gear and get the same results. You say "no compression". Are you sure? You can turn most engines over by hand even at normal compression, if you turn slowly enough. Pull the spark plugs and see if it turns easier. Put your finger over a plug hole and see if you feel compression when turning it over.
I'm assuming the 240 is a late version of a C. If that assumption is correct, then the camshaft is gear driven from the crank. The only way I'm aware of to have a COMPLETE loss of compression is if the cam isn't turning, and even then, at least ONE cylinder should have both valves closed and have compression. (Of course, if the crank isn't turning, you'd get the same symptoms) Check these things and get back to us, with more info we can come up with more things to check.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
