Re: still trying to set the timing on my 44 H, I'm
Posted by tanner clark on January 02, 2005 at 05:46:28 from (69.243.23.210):
In Reply to: still trying to set the timing on my 44 H, I'm clo posted by tanner clark on January 01, 2005 at 14:41:15:
Hey guys, thanks for the responses. It might be a simple question but I know that engines are different in cylinder alignment. With this motor looking at it from the Dist. side, no:1 is at front nearest the radiator, is it safe to assume that the cylinders follow order from there sequentially, meaning, then no:2 then no:3 then no:4 from front to rear of the motor? And hypthetically speaking from the directions below, setting TDC for the no:1 cylinder could be done just by setting the pointer on the first of the double notches, correct, or is there basically a 50/50 chance that it would be the compression stroke or the exhaust stroke? I just wanted to ask the obvious questions so I can follow through with your good directions below.
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
