Farmall Tractors Discussion Board
Re: Re: M- 12 volt conversion
Posted by Tractor Guru on November 25, 1999 at 08:39:57 from (192.156.19.50):
In Reply to: Re: M- 12 volt conversion posted by The Red on November 25, 1999 at 05:03:38:
One way you could do this is to get a Delco alternator from Tisco. This is a one-wire alternator. Use #10 wire from the alternator to your amp meter and back to your battery. Leave your 6-volt stater alone. It will take 12 volts. Put a resistor on your coil and change lightbulbs (because the 6-volt lightbulbs would burn out).
Post A Followup
: Re: Re: Re: M- 12 volt conversion
