Re: Farmal M Brake drum
Posted by TDK on January 02, 2005 at 18:56:11 from (152.163.101.13):
In Reply to: Farmal M Brake drum posted by Dennis Stuhr on January 02, 2005 at 16:33:16:
You may need a puller to remove drum. Penetrating oil and heat will help also. Lay a straight edge across braking surface of drum, if it's worn more than 1/32, have it turned. This will make a big difference in braking.*Don't forget to replace the bull pinion seals that drum runs in.* New seals are thinner than the original ones,so two per side can be used & is recommended.No need to paint anything inside, your choice.
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
