Re: still trying to set the timing on my 44 H, I'm
Posted by Tanner Clark on January 04, 2005 at 04:09:16 from (206.239.4.3):
In Reply to: still trying to set the timing on my 44 H, I'm clo posted by tanner clark on January 01, 2005 at 14:41:15:
Ok the wife and I set the timing last night using the handcrank and got the no:1 on TDC. The pointer was just between the double notches on the pulley. I was able to see the piston real easy, and it had a lot of junk on the top of it. But anyway, The rotor was pointing at like 6 o'clock instead of 2 o'clock, so I pulled it off and turned the gears so that it was sitting at 2 o'clock. I then wired it up, checked everything, put the battery in, and hit the starter. Nothing happened. So I am back to where I was. The only things I have not really checked out is the voltage regulator or the 12 volt generator. Could these be a problem? Frustrated yet again.
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
