Re: 806 shifting
Posted by the tractor vet on January 04, 2005 at 08:12:59 from (4.124.69.53):
In Reply to: 806 shifting posted by bill smith on January 04, 2005 at 06:13:02:
You can adjust till you are blue in the face the fact is you need to start repairing . First ya need to replace the as i call them the cubcadet tie rod ends all the headed pins then you need to pull the op cover on the range transmission and the side plate , the side plate need to come off before you pull the top so you can watch the rev. shifter rod and fork as you come up whith the top cover . Then you need to see just where all the movement is and fix or replace what is wore out . The rod that goes into the rev. shifting fork is wore out in the key slot and needs to be replaced and you may find that you have some rollers that are missing . the top cover is probably wore bad and can be rebushed but you will have to find a machine shop that knows what they are doing to get it centered up and make a bushing and rebore the hole on center all slop must be removered you can buy and aftermarket cover but i pefer to install a bushing in the old. look at the cam and see just how bad it is and replace if you have to , the shaft that goes into the cam is probably wore and will need to be replaced . All this has started from the hard shifting because the clutch linkage was not kept in adjustment and the dump vavle got out of wak and made for hard shifting and people just started to ram it . When everything is set right they shift nice.
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
