Re: help with 12 volt conversion
Posted by farmallhal on January 04, 2005 at 18:19:19 from (216.106.33.33):
In Reply to: Re: help with 12 volt conversion posted by jeff smith on January 04, 2005 at 16:25:34:
Jeff, I don't know how to advise you from here if you have it wired per Bob's diagram. As far as testing the ammeter I think you could attach a light (a fan motor or a cigarette lighter would be better) or any 12 volt item which will draw current to one side and a feed from the battery to the other side and see what kind of deflection you get in the pointer when powering up the 12 volt item. You will also have to ground whatever you are trying to power up to the same ground plane to which the battery is grounded or directly to negative post on the battery. You can do this on or off the tractor as long as you can connect the ammeter in the circuit. I would think you should unhook the other leads to the ammeter when doing this test as you just want to see if current is being measured through the ammeter. This electrical trouble shooting is not my speciality in great detail but I do have somewhat of a working knowledge and have been able to survive. I would also put in that 10 ohm - 10 watt resistor I keep talking about as that should be enough draw to excite or start your alternator into a charging mode. I was told the resistor needed to be soldered to the wires for the best connection. Was very easy to do and then go back and install a light along with the resistor once you get this all straightened out if you like the light. Those resistors are really very cheap at Radio Shack. I have only done this conversion once and then with the Hitachi 14231 alternator. I take it you are using one of those older 10SI Delcos and not something which might have an internal diode which would cause problems with what you are trying to do? You should have had a voltage regulator in conjunction with the generator and that should be totaly disconnected out of the conversion as the alternator should have an internal regulator. Send me an email to russell@wavecomputers.net if you feel you need Bob's email address to get this completed. We all want you to succeed in this endeavor and will help in any way we can. By the way where are you locatedin this great conuntry? Good luck and hang in there and let us know how this progresses, Hal
Home
| Forums
Today's Featured Article -
Check Your Coolant - by Bill Radford. Great tips on how and when to check the coolant in your tractor.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
